Looking for sample config of NME-AIR-WLC-K9 module
thags
HI Guys
Hope you well.
I have 2 quesries whihc i need you advise on as folowows
  • The installation of teh above card and configuration sample of this controller module on a router.\
  • The second query which i ned you guys to confirm but from what i have seen on pdf ,is that this card will onlu work on 2800 and 3800 routers.So therefore if you have a 2921 this module will not work since pdf say if you use a 2921 you need to purchase the SM-NM-ADP module.
       As per above statement is cisco sayin you need the SM0nm Adp moduel and the NME -air -WLC -k9 card to work on a 2900 or 3900 router.
I would kindly appreciate you advise on the following
Thanks Thags
0 Replies 0
