LWAPP Ap boot problem
darrell.lewis
Visitor
I have a 1252 Ap that was booting to LWAPP software and connecting to a 4402 controller. It suddenly stopped booting into the LWAPP code. I can reach the Ap by telnet and it seems to boot to Autonomous mode. Is there any way to start the boot into LWAPP from the command prompt? Thanks in advance.
Vinay Saini
Are you sure AP turned to Autonomous from LWAPP ... that;s weird ..
Can u run folowing cmds on AP
1. Debug lwapp client events
2. show lwapp client rcb
Just wanted to make sure it is not lwapp 🙂
Vinay
Both commands come back as invalid. I'm also sitting at an ap# prompt.
I've figured out the problem....One of my partners reloaded the Ap with Autonomous code which explains why it was autonomous. I knew it just doesn't happen. Thanks.
