LWAPP virtual interface
dominic.caron
Level 11
Level 11
The Virtual interface is use for communication between client and WiSM. It the interface realy local to the controler or will it get in my MSFC routing table. Is it trully isolated form the network?
Thk.
jakew
Level 5
Level 5
The virtual interface IP address must be non-routable. It should also be the same address on all controllers in your mobility group.
- Jake
