macbook pro and wireless
HUGH LANCASTER
Level 3
Level 3
Windows 2008 rw with Certificate server and NPS, Windows client connect no problem. Cisco 1252 AP's, Cisco 2106 controllers
I have installed certificates on the Macbook pro's and can connect to the wireless -wpa2, peep, etc. Two problems I am experiecing. 1- I cannot login from the macbook with active directory users credentials. Looking at the top-right of the mac screen, no wireless connection. I can login with local user account and connect to the internet everytime; however, sometime I cannot connect to the windows server  - mapped home directories, smb://encsd5/data5/Shared, I have these mapping setup under "connect to server". Any ideas! Is it a windows problem or a wireless issue. What logs do I need to be observing??     Thanks for any help!
The issue with shared folders depends on if the device has joined to the wireless prior to the device trying to connect to the shared using login scripts.  Your login scripts will fail to map a drive if the machine hasn't joined the wireless.  This is why machine authentication works better than PEAP (AD credentials).  With machine authentication, the device will connect to the wireless and then the user is prompted for their login.  This way when the login scripts run, they will be able to connect to the share.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
29 Replies 29
Scott Fella
Hugh,
I have no issues with 802.1x PEAP with my MacBook Pro connecting to my home network nor any of my customers. I don't have to install any certain either. The share might be both a windows and Mac problem. I have seen some people complain about this in the past, but I have been able to have shared folder connect fine from MacBook but to a NAS not a windows server.
-Scott
HUGH LANCASTER
Level 3
Level 3
Can you login with AD credentials? Any suggestions on how to troubleshoot this. My windows client connnect with no issues.
Yes I can! I run an AD at home and my iPad and iPhones also use AD credentials. The best thing to look at is the radius server logs.
-Scott
As you can see, I connecting. However, I cannot login with AD credentials. I must first login with mac account. Another thing, NPS displays PrintShop4 and I am signing in with printshop2. ???
Network Policy Server granted access to a user.
User:
Security ID: ENCSD\PrintShop4
Account Name: printshop4
Account Domain: ENCSD
Fully Qualified Account Name: ENCSD\printshop4
Client Machine:
Security ID: NULL SID
Account Name: -
Fully Qualified Account Name: -
OS-Version: -
Called Station Identifier: c0-7b-bc-96-15-60:WLC
Calling Station Identifier: 14-10-9f-db-31-83
NAS:
NAS IPv4 Address:
NAS IPv6 Address: -
NAS Identifier: Cisco_e2:31:60
NAS Port-Type: Wireless - IEEE 802.11
NAS Port: 1
RADIUS Client:
I see why I NPS is showing Printshop 4. Assistant logged into the wireless network as printshop4. I removed and now logged in as printshop2. Now if I can figure out how to login with AD credentials.
When you create the wireless profile in a MacBook you choose WPA2-Enterprise. It will then ask for your AD credentials when connecting to it the first time. Try putting just the username and password or the domain\username.
-Scott
I deleted and re-created the user wpa2 enterprise and have internet access. Also, previously the computer account was not still under computers in AD so I moved it to the printshop account. Now at the login I see wireless active. I then login but not seeing printshop directory. I go to "connect to server" select smb://encsd3/data/printshop connect and get error "there is a problem connecting to the server"encsd3".
Have NPS radius client  for each controller, have connection request policy for each controller. Conditions: NAS IPv4 Address ( create one for each controller, NAS Port Type Wireless - IEEE 802.11 or Wireless -Other
Network Polices: Windows Groups : Encsd\Domain Users or Encsd\Domain computers
NAS Port Type: wireless -IEEE 802.11 or Wireless- other
NAS IPv4 Address : ip address for each controller
If you have network access then the WLC and radius are fine. Getting to a windows share from a Mac might be the issue you have their.
-Scott
Scott Fella
How does your policy on NPS look like?
-Scott
User:
Security ID: ENCSD\PrintShop2
Account Name: PrintShop2
Fully Qualified Account Name: ENCSD\PrintShop2
Client Machine:
Account Name: -
OS-Version: -
NAS:
NAS IPv4 Address: 10.100.0.49
NAS IPv6 Address: -
NAS Port: 1
RADIUS Client:
Client Friendly Name: WLC3
Client IP Address: 10.100.0.49
Authentication Details:
Connection Request Policy Name: Use Windows authentication for all users
Network Policy Name: WLC3
Authentication Provider: Windows
Authentication Server: ENCSD4.encsd.net
Authentication Type: PEAP
EAP Type: Microsoft: Secured password (EAP-MSCHAP v2)
Account Session Identifier: -
Logging Results: Accounting information was written to the local log file.
Quarantine Information:
Result: Full Access
I have rebooted several times and using "connect to server" I am able to map to the folders; however, not consistent. Sometime fails. Still not get wireless reception before login. If I could login the AD server upon reboot, may solve my problem.
You will not get a wireless connection prior to login unless its a  domain machine.  Apple devices needs to fully come up and then it will  join the SSID.  You might want to take a look at this:
http://tinyurl.com/pvrxdby
Scott
-Scott
Thanks for the link but I can't open it.
http://tinyurl.com/q5rhsq3
Scott
-Scott
