Manage multiple wireless controllers
r.lundrigan
Community Member
I currently have 3 3850 stacks each on separate floor. Each one is running as a mobility controller with 4-6 APs connected to each controller. I'm looking for a way to centralize everything. Meaning, take a 3850 and turn it into the main mobility controller to administer the entire WLAN without having to have a separate controller for each set of APs.
Rasika Nayanajith
This is NOT possible.
Only workaround is to use Cisco Prime Infrastructure to push template configuration for each of these switches. I believe IOS-XE 3.7 is onward required for this.
See below post for more detail
http://wirelessonthego.postach.io/post/best-practices-and-golden-configs-converged-access-branch-deployment
NB: If you need to manage all your APs from single controller then you need to go back to AireOS products (eg 8540/5520/5508/2504)
Rasika
*** Pls rate all useful responses ***
