Management access for 1832i
prashanma
Can we use Web GUI and SSH for manage  the AP ? As far as i know it can be done, but couldn't find any documentation. Any documentation regarding the manage AP
pieterh
if you use the AP in combination with a WLC (wireless controller) then you need to enable SSH and web access first using the WLC management CLI or GUI
if you are using the AP without controller using mobility express you can look at this document
Cisco Mobility Express User Guide for Release 8.1 (or any other version your access point is running)
pieterh
Thank you Pieter
