08-29-2024 01:36 PM
Hey Guys!
The question is simple, Which options are "good" this day for a captive portal like an airport? I wanted to deploy somthing similar in the network, but, the solutions that I have founded ended in an ISE. is ther another options?
I just wanted a guest user put her personal information email/company and logg into the guest Network.
Note: I have C9800 deployed in the network
Solved! Go to Solution.
08-29-2024 11:20 PM
- You may find this presentation useful : https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKEWN-2014.pdf
M.
09-01-2024 07:17 AM
@MHM Cisco World they said "Note: I have C9800 deployed in the network" so that would be new
08-29-2024 11:20 PM
M.
09-01-2024 03:09 AM
There are many options. It really depends how many features and options you want to have and how much you want to pay for the service.
If you want to keep it with Cisco then Cisco spaces: https://spaces.cisco.com/store/product/captive-portals/ with the option of OpenRoaming: https://spaces.cisco.com/store/product/open-roaming/
Other industry leaders to look at (amongst many others):
https://purple.ai/products/guest-wifi/
https://www.elevensoftware.com/solutions
09-01-2024 07:05 AM - edited 09-01-2024 07:23 AM
Webauth pass through which support in old wlc for new wlc I don't know, I will check if wlc 9800 support this l3 security or not.
MHM
09-01-2024 07:17 AM
09-02-2024 09:47 AM
Thanks all for your feedback!
