Mast Mount Sector Antenna
edwardsjj
A customer (a truck inspection site) needs Wireless access outdoors in thier truck inspection area. I'm going to install a Mast Mount Antenna outdoors and run a cable to an Aironet 1200 indoors. My question is, do I only use one(1) antenna or two(2)?
smahbub
Level 6
Level 6
You will find all the information that you need to install the Cisco Aironet Omnidirectional Mast Mount Antenna at the following URL.
http://www.cisco.com/en/US/products/hw/wireless/ps469/prod_installation_guide09186a008028606d.html#wp26858
This URL explains the installation, safety precautions and other technical details of the antenna. Hope this is useful.
dorinda.nesmith
One will work.
