Max AP per VLAN
sjean
Community Member
What are the Cisco Wireless best practices for VLAN segmentation ?
- Maximum access point per VLAN ?
- Cisco WLC on a dedicated VLAN ?
2 Accepted Solutions
Rasika Nayanajith
There are no recommended value for max AP per vlan. /24, /23 subnet size is most common.
If you have a large number of APs then it is recommended  to separate AP mgmt from WLC mgmt to prevent all AP broadcast reach & burden WLC.
Rasika
**** Pls rate all useful responses ****
Sandeep Choudhary
Totally Agree With Rasika..
Just my 1 cent...
As per my experiences (50-80) is more then enough on 1 VLAN. This action prevent from re-association during network failure"
If you are using the same VLAN from WLC management & AP then dont put more then 20-25 AP(Again as per my real life exp.) otherwise broadcast messages generated by APs & some discovery messages may get dropped and it will make the AP joining process slower.
My recommandation is that you must keep the WLC and AP on different subnet.
Dont forget to rate helpful posts
Rasika Nayanajith
Rasika
Sandeep Choudhary
Just my 1 cent...
