MAX NUMBER OF WIRED USERS ON THE 1810 AND 1815t OEAP FOR CORPORATE CONNECTION
DanDeg
Hello...
If I connect a dumb switch on PSE LAN1 or LAN2 (or both) on the OEAP 1810 or 1815t how many wired users can I connect to it for corporate connection?
On the old 600 series i am able to connect 4 wired users on port#4 for corporate connection.
Thank You
DanDeg
you can do a max of 8.... 4 on PSE lan1 and 4 on lan2.... that means you have to have 2 dumb switches.
