Max Web Auth Bundle
carlos.joya
Visitor
Hi everyone,
I have a Cisco WLC 5520 and I'm creating a new SSID for Guest users and I want to use a customized Web Auth bundle but I have already downloaded one for another SSID that is currently working, my question is if, when I upload another one it will replace the ones I already have or if there is a restriction in the quantity of these.
I appreciate who can help me with this.
Have a great day.
Sandeep Choudhary
May be you can merge two webauth in tar file and then download on WLC.
Then use specifc files for specific WLANs.
I would suggest to keep one webpage as name login.html(for one wlan) and for other wlan you can have diff names(example: login_guest, etc....).
Dont forget to rate helpful posts
Sandeep Choudhary
Hi Sandeep
Thank you, that's the solution, I did that keeping the actual bundle with the new one on the same .tar file (using the same login.html and the new one has another name) and then downloaded into the wlc.
Have a nice day.
