Maximum AP's
billybong
Level 4
Level 4
Hi All,
Would someone be able to tell me the maximum AP's supported by my AIR-CT8510-K9, It says 6000 but is that only a maximum if i bought the license or is that default
(Cisco Controller) >
(Cisco Controller) >show license in-use
There are no licenses
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
RTOS Version..................................... 7.4.100.0
Bootloader Version............................... 7.3.101.0
Emergency Image Version.......................... 7.3.101.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_cf:77:a6
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1615
Redundancy Mode.................................. Disabled
IP Address....................................... 192.168.2.1
System Up Time................................... 0 days 0 hrs 6 mins 42 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
--More-- or (q)uit
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +19 C
Fan Status....................................... OK
RAID Volume Status............................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 70:81:05:CF:77:A0
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 6000
2 Accepted Solutions
Default is Zero.
But if you can enable the evaulation license on it then you can connect APs to WLC.
Dont forget to rate helpful posts
It doesn't have a time limit, but Cisco did this to make it easier for the customer and again, it's a trust between you and them:)
-Scott
-Scott
11 Replies 11
Rasika Nayanajith
Yes, you need to buy the license for the amount of AP you need.
6000 is the max no of AP this platform could handle.
Rasika
Thanks for replying Manannalage, would you know what the default amount AP's i'm able to use with out any license's
Default is Zero.
Thanks Guys great answers, would either of you guys have a link so i can see how the licensing works on this unit please
The 8510's have right to use licensing, but you still should buy license for TAC support.  Here is the 8510 licensing FAQ:
http://www.cisco.com/c/en/us/products/collateral/wireless/flex-7500-series-wireless-controllers/qa_c67-713536.html
-Scott
-Scott
Thanks Scott, thats great, just one question about the RTU license does it have a time limit?
-Scott
-Scott
Perfect Thanks for all the help guys  🙂
Glad to help out!
-Scott
-Scott
Here is the configuration guide that explains the licensing also:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/configuration-guide/b_cg81/b_cg81_chapter_011.html
-Scott
-Scott
With RTU right to use licensing, it's a trust between you and Cisco. You can enable all 6000 and use it, but you really shouldn't without purchasing license. It will also come down to support contracts.
-Scott
-Scott
