maximum APs on PI Map
Hi All, what is the maximum Number of Access Points on a Map in PI 3.4? Is there a hard limit, or Best Practice? I have to put between 200 -  300 APs in one Map, one Building with 20 Floors. The PI is working with MSE and CMX.
TiA, BR, Michael
I older PI versions the limit was 100 APs. https://www.cisco.com/c/en/us/td/docs/wireless/prime_infrastructure/1-3/configuration/guide/pi_13_cg/maps.pdf
I believe there is no hard limit in newer versions, however, it will take looong long time to load floors with 200-300 APs. That's why it is not recommended to go over 100 APs per floor. It is better to break down the floor in smaller areas so you can group <100 APs per map.
** Please rate helpful posts **
CCIE #58023
