Maximum Minimum Firmware versions
Dylan Hyndman
Level 2
Level 2
I've searched the Cisco site and not found any answers to this so I'm asking here. Does anyone know the maximum/minimum firmware versions for the follwoing access points:
AIR-LAP1142N-E-K9
AIR-LAP1242AG-E-K9
AIR-AP1852I-E-K9
AIR-CAP2702I-E-K9
AIR-CAP2602I-E-K9
I'm in that difficult window between WCS and CPI and looking at newer WLC's and need to ensure that I can continue to manage my estate of AP's. I'm also looking at moving from 5508 to 5520 WLC's but Im told these only support a minimum of 8.1, this means that I have to wait until I get migrated to CPI as the WCS will not do 8.1, but will the AP's do 8.1 eeek!
Dylan
Sandeep Choudhary
AP MODEL                       -  MINIMUM       MAX
AIR-LAP1142N-E-K9        -  5.2.157.0       - All till Today
AIR-LAP1242AG-E-K9     - 3.1.59.24        - 8.0.X
AIR-AP1852I-E-K9           - No Idea(No idea about this AP, typo error from your side)
AIR-CAP2702I-E-K9        -  7.6.120.0       - All till Today
AIR-CAP2602I-E-K9        -  7.2.110.0       - All till Today
*** All AP will support 7.6.120/7.6.130 or 8.0.X version on WLC. 8.1 is support by all APs except 1242AG.
If you have WLC with 7.6.120/7.6.130.0 or 8.0.X then you can manage all APs.
WLC : you can go for 2504 or 5508.
Don't forget to rate helpful posts
Thanks for the info Guys, appreciated.
Cheers
Dylan
mohanak
