Maximum Performance External Antenna
ricardorojas123
Level 7
Level 7
What setting or parameter in the configuration of a LAP registered in a WLC, I lets me get the most power or best performance in an external antenna? (The access point model is 1520 Series)
Ryan Curry
Level 5
Level 5
Depends on the antenna being used.  Here's a good link to check out the goes over the different antennas and what APs they can be used with:
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
