ME issues with Airprint
Ibrahim Ramku
Hi All,
I have deployed a couple of Mobility Express environments with 1850/1830 series APs. I have the AP-s connected to some Cisco SG300 where we have a printer with airprint enabled. Airprint does not seem to work. I had similar issues with the traditional 2504 WLC, but they were solved by changing the WLAN to use local forwarding instead of the centralized forwarding.
I have tried a few options, including enabling broadcast/multicast forwarding, bridging of local traffic etc, but none of them seems to work.
Has anyone else experienced/solved a similar issue?
BR,
Ibra
BEN ROBINSON
 I also am having an issue with airprint not working in this scenario… Please advise if you find a solution I'll do the same
BEN ROBINSON
We connected the AirPrint devices to the SSID on the 1850s and go to the Printers web portal via printers IP to configure AirPrint - then toggle the AirPrint service off and on and works for us. Simple fix on our end
