measure distance by Cisco Power Level
giangle
Hi all.
In Cisco Wireless Controller, I saw AP with power level = 1. How I know distance one user mobile connect to this AP with good signal -65 dbm.
It's the same for power level 2,3,4.
Thanks!
Leo Laohoo
Not remotely accurate because of attenuation, wireless client Tx power, etc.
ammahend
As Leo mentioned it’s hard to say because of attenuation factors and client TX power.
you should do a survey to find out at what distance you see signal strength at -65dBm, if you don’t have survey tool, then you can just use wifi analyzer app (only on Google store). It’s good enough to answer your question.
For different power level value, refer to this post
https://community.cisco.com/t5/wireless/maximum-power-level-assignment-vs-tx-power-levels/td-p/2853296
hope this helps
-hope this helps-
