Meraki APs
subarayarsooper
Level 3
Level 3
I am having 10 branches along with HO. All 10 office have 5 wifi users. They all need to connect to access points and go to firewall and all are site to site tunneled to HO. All the users have to communicate with each other. If i go with one MR28 per branch, shall i achieve the control through meraki dashboard and can they commuicate with each other?
primary objective is to users have to commuicate with each other from all branches with HO.
8 Replies 8
CMR
Meraki Community All-Star
@subarayarsooper ideally you'd want an MX at each branch and with small branches like that you could use the MX67 or MX68 unless you need large amounts of bandwidth. You could also use the W versions with built in wireless instead of the separate MR28 if they are all near the router.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
subarayarsooper
Level 3
Level 3
@CMR but there is already site to site VPN established using the fortigate firewalls.
CMR
In which case you do only need the MR28s as suggested. They will control the wireless access and the FortiGates will control the site to site connectivity.
@CMR is that not possible to control Access points?
CMR
@subarayarsooper the only way to control the site to site communication using Meraki in your case, would be to add an MX at the Head Office. The SSIDs on the MR28s could then be tunneled back to it and therefore controlled in the dashboard.
subarayarsooper
Level 3
Level 3
@CMR here i am not asking about controlling firewalls. I know only meraki devices can be cotrolled via meraki dashboard. i am asking shall we control the wireless access points with the site to site vpn established between ho and branches
CMR
Yes, all Meraki equipment is controlled through the Meraki cloud dashboard.
MerakiGnome
Morning @subarayarsooper, your design/thinking is correct. Your site to site connectivity is done via your FortiGates and your MRs/Wireless will be managed by the Meraki dashboard. Wireless traffic from one site will be able to traverse your WAN and reach the devices across your network. Just as long as your routing is correct and firewalls permit the traffic.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
