Meraki MR53 AP and Power Injector
BrandonKim21215
Current situation - we have multiple Meraki MR53 AP's.  Our current switches do not have PoE ports, and the areas that we would like to install the AP's, do not have power near by.
Will I be able to use a power injector installed in the IDF to supply power to the AP?  I don't need to use both the power injector and power block right?
If you could also include the model number of the power injector that will work with the Meraki MR53, it would be greatly appreciated.
Scott Fella
You can use a power injector as long as its within the 100 meter limit including any patch cables.
-Scott
