05-28-2016 07:43 AM - edited 07-05-2021 05:08 AM
Hi Expert,
I would like to ask for a test plan about Meraki Wireless Network, including ap connection, user connection, speed limitation, etc,
thanks so much
05-28-2016 12:31 PM
You "test" for an "outcome". What is the outcome you are trying to achieve, and what would constitute a "pass"?
Once you know where you want to end up, the steps needed in your testing are likely to become clear.
05-29-2016 01:28 AM
Hi Philip,
Thanks for your answer. I setup Meraki wireless network for customer, and customer test the wireless network according to the plan which i draft. So, I would like to ask for a test template about Meraki wireless network
05-29-2016 01:12 PM
1. Verify you can connect to the SSID.
2. Verify you can ping a needed resource.
05-29-2016 05:42 PM
Hi Philip,
do you have specific document on it?
05-29-2016 05:45 PM
No. Unless you have a specific outcome to test for, all you can do is to test for basic connectivity.
