Meraki roaming not supported devices
HonzaVejsada
Dear all,
My question is maybe a little bit newbie, but I would like to turn on Meraki roaming. In our office, we have many devices which support this feature BUT few devices which not...and I am not sure if the Meraki roaming will have a negative effect on these not supported devices.
Can someone explain this case to me like to his/her grandmother, please?
marce1000
 - You may find this thread informative : https://community.meraki.com/t5/Wireless-LAN/Bad-roaming-in-Meraki/m-p/11595
 M.
Philip D'Ath
There is nothing to "turn on" to enable ordinary layer 2 roaming. Could you tell me if you're referring to something else?
Devices will already be able to roam between access points.
Ideally, you should be bridging your SSID to a local VLAN (or even just the native VLAN).
