Mesh AP1522 typical distance coverage
tapanglf
Need some help. We are planning to install outdoor mesh using AIR-LAP1522AG-E-K9 with AIR-ANT2450V-N (2.4GHz) and AIR-ANT5180V-N (5.0GHz).
What are the typical distance it can cover? Assuming open space?
Ive searched but could not find a proper documentation?
All i found was Data Rate-to-Receive Sensitivity.
Any Data Rate-to-Distance reference someone have stumbled upon?
Kindly point me where the particular info is located?
Leo Laohoo
Will this Calculator be of any assistance to your query?
Cisco 1520 Series Outdoor Mesh Range Calculation Utility
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps8368/1520_Link_Calculator.xls
Does this help?
Leo Laohoo
Does this help?
tnx leo.
the utility was a great help...
would you know if the utility is calculating for overlap as well?
Not sure.
