11-29-2015 11:28 PM - edited 07-05-2021 04:19 AM
Dears
recently we add around 65 access points(1552 requalarity is -M) in outdoor area , after installtion I found too many MAPs rejoining and chainging its parents frequantely . then I found RADAR signals effeceing on 100,104,112,136,140,149,153,157,161 channels (the remainings are only two channels 116 , and 132) that is not enough for around 15 RAP , how can I increase the number of channles for backhaul not clients? is there anyway to avoid the RADRA signal ?
11-30-2015 01:37 AM
did u check this document befor mesh AP implementation????
If not then go through once: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/91565-radar-survey-wmn.html#r3
also check this, it may help you:
https://rscciew.wordpress.com/2014/11/15/wlc-mesh-network-configuration/
Dont forget to rate helpful posts
11-30-2015 01:44 AM
