MESH Compatible APs?
NotMeHere
Level 3
Level 3
So, I took a "class" recently on Cisco MESH. It was only 1 day long, so I didn't become very well versed. My question is this... Which APs support MESH? I know that 1500's support it and in the class we did it with 1030's, will 1020's support this? Also will IOS converted to LWAPP AP's support MESH, specifically 1240's? I've searched but can't find this on the Cisco site.
Thanks in advance
Paul
aghaznavi
Level 10
Level 10
I don't think 1020 supports it.
The 1030 Remote Edge AP supports outdoor mesh but is limited to a single hop. Multi-hops are supported by the 1500. The 1020 does not support mesh.
But what about IOS converted APs? Will any of them support MESH? Specifically the 1240 series.
