Mesh Minimum SNR to the MAP to look for better path
aous.salloum
Hi Guys,
I have an issue where in a mesh network , the MAPs are connected to very far MAPs / RAPs with lower SNR.
is there a way to configure minimum SNR for the MAP to start looking for a better Path ?
also what is the interival that a MAP check the neighbors info to decide on the best path to take.
Much appreciated.
Aous
I know the documents and couldn't find what I am asking for!
thanks though :)
The docs posted does have good information on AWPP process. You can’t set the min SNR, but you set the data rate to allow for minimum SNR.  If you have multiple hops back to the RAP, the higher the data rate the better. So that might mean more RAP’s or directional antennas for the backhaul depending on the MESH AP you are using.
-Scott
