Mesh signal strength -65 dBm
ioan_ploscariu
I have a mesh wireless solution with 1 WLC 2112, 4LAP 1522, one 8dB 2.4 Ghz antenna/LAP 1522.
Software version on WLC 2112 is 5.2.157 and TX power level is set to 1, but maxim signal strenght is -65 dBm.
What I make wrong?
wg wireless
At what distance from AP you are measuring -65 dBm? Also, are this may be related to some obstacles or the layout of the surrounding area.
Also, 1522 supports three 2.4 GHz antennas which will improve client to AP traffic.
The distance is 1 meter and is not any obstacles.
