mgmt over wireless not working
tpahuja
Level 3
Level 3
Folks,
          I have mgmt over wireless disabled on my controller but still able to GUI and telnet into from a client connected to one of the APs registered with the controller.
I am running 7.0 code. The output of "show network summry" clearly shows that mgmt via wireless is disabled.
Any advice would be highly appreciated.
Parwal
daviwatk
Level 8
Level 8
What mode is the AP in that your are connecting to? Is this a local mode AP, or is this perhaps an H-REAP AP using a locally switched WLAN? What's the exact 7.0 release you are using?
Leo Laohoo
It's a known bug.  This feature has been broken since 6.0.198.0 (if I remembered correctly).
