Microsoft Out Look Problem
nishanthjavvadi1
Community Member
Hi there,
We have wired PCs in our netwok we have migrated to wireless few months back now we have only few wired PCs, We are facing a problem from wireless PCs they are not able to access Microsoft Outlook only wired PCs are able to access. Can you please Suggest me where might be the problem before this problem Wireless PCs where able to access Microsoft Outlook.
Thanks & Regards
Nishanth J
Sandeep Choudhary
I think this is not the issue with wirelessLAN.
It is something problem with ur laptop app or exchange.
Just try to open any other web page and try it.
Check setting for SMTP and pop3 ports and compare these setting with machine which works.
Hope it helps
