Migrating configuration from 2500 controller to 5520 controller
sergef1973
Is there a way to migrate (Export/Import) configuration from 2500 Wireless Controller to 5520 Wireless Controller.
Thank you,
Serge
Leo Laohoo
Export the config of the 2504 to a TFTP depository.
Import the 2504 config from the TFTP depository to the 5520.
Sandeep Choudhary
Make sure both WLC have same software version then only it will import &Export the correct config.
Dont forget to rate helpful posts
