Minimum acceptable power input for Aironet 1200
millerlw
Does anybody know the minimum accecptable input power for the Aironet 1200? I know the max is 48v DC but cannot find what the minimum is that will keep the device running with only a couple of clients. The reason I ask is that I am going to try to get one installed in a Bradley Fighting Vehicle, but the only power converter they can supply has a maximum output of 15v DC. And there are no standard 3 prong plugs and installing a 24v DC - AC inverter is not possible.
This is only for testing, but if it works it will have to be installed in alot more vehicles.
Leonard
dominic.caron
Level 5
Level 5
Then tension require by an AP is 48v DC 5%.
It's quite easy to convert 15v to 48v if there is enought power. This is a commercial solution:
http://www.fuelcellstore.com/cgi-bin/fuelweb/view=Item/cat=13/product=579
If you have volume, this unit is overprice, You might be able to get your hand's on a low power model or to get a compagny to make it for you...simple electronic/first year eng. course material
