Mixing Country Codes LAP within same building and controller
mal jackson
Here in the UK, my region code is "E" - so the LAP I install would be e.g. a 1815W-E-K9.
BUT, I have some 1815W-A-K9 and country AR for Argentina. Obviously these will be mixing, within the same building and controller, with existing LAP with region "E".
I'm still getting a test rig set up, but technically this looks possible.
My question is, even though technically this may be possible, is there any reason why I would not want to do this.
Many thanks!
Mal.
pieterh
administration is more complex when DCA/RRRM want to assign "country channels"
When number of access points increases it is easier to assign a controller per regulatory domain.
this document may help https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/country_codes.pdf
you will find you can configure advanced options to specify country per access point.
Leo Laohoo
It will only make things worst.
Only common channels will be enabled. This means the -A will be broadcasting with fewer channels.
Use incorrect APs with the wrong Regulatory Domain at your own peril.
