MLPP with LWAPP deployement
fredpoint
Community Member
I would like to know if you LWAPP APs can handle MLPP. My feeling is that is not possible since MLPP use RSVP on each node on the path and since QoS in LWAPP mode is propagated via LWAPP tunnels. Am I right? For example I want to deploy Aironet 1500 but I can?t see if they support RSVP.
Fr?d?ric Point
drolemc
Level 11
Level 11
Yes you are correct. MLPP with LWAPP is not supported at this point of time. To know how QOS is implemented in WLCs read http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807e9717.shtml
drolemc
Level 11
Level 11
