04-11-2016 08:04 AM - edited 07-05-2021 04:53 AM
Hi Guys
I have a WLAN where the customer is facing an issue with Guest users (CWA).
The client need to re-authenticate when roam from WLC-1 to WLC-2, we have a Mobility Group between the Controllers but looks like it´s not working.
We are using WLC 5508 (Version 8.X) and ISE to authentication the Guest users .
Any help will be appreciated
04-11-2016 04:41 PM
"show mobility summary" output should verify the mobility status of your WLCs.
If mobility tunnels are down see whether any config issues. Below may help to understand what configuration required
https://mrncciew.com/2013/05/20/mobility-config-via-cli/
Rasika
04-11-2016 05:45 PM
04-11-2016 06:26 PM
I would then take a "debug client <client_mac_address>" output from both controllers when this client roam occur & see what info WLC gives about this.
In your setup which controller act as Anchor for Guest SSID ? Have you configured Guest Anchoring for that SSID ?
https://mrncciew.com/2013/03/22/auto-anchor-mobility/
Rasika
04-12-2016 06:26 AM
04-13-2016 12:06 AM
Hi Bruno,
Check these client debug file info analyse via below Debug Analyzer tool, You will see 5 different connection attempts, sometime it roamed to an AP and sometime it is a new association.
https://cway.cisco.com/tools/WirelessDebugAnalyzer/
If I get time I will post some of screenshot to highlight this
Rasika
