Mobility group only works using management interface?
ecarbajo
Hello,  in order to stablish the control traffic between 2 WLC-5508, it's necessary to use the management interface??
It's possible using a dynamic interface o service port ?
I think it only works with management interface,  but I don't understand the meaning of this text in the Configuration Manual:
"Mobility control packets can use any interface address as the source, based on routing table."
Thank you,
Scott Fella
No... mobility communication is done only with the management interface.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
