Mobility group same ssid multiple WLC
DARRELL MILAM
I have a 4400 and a 5508 WLC in the same location
We want to be able to roam between ap joined to both the 4400 and the 5508 using only one ssid
Do I only need to create a mobility group and add both WLC
then create only one WLAN on one of the controllers and it will be shared across bot WLC.
Or something else?
5 Replies 5
Saurav Lodh
Level 11
Level 11
Resolution :
Yes you are correct. Please follow this link for Mobility groups and Roaming :
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_mobility.html
Thank you
I'll give it a try.
Is there any down side to configuring 2 WLC this way?
Not sure but it did not work.  The mobility group shows up on both controllers but when I connect to the WLAN then roam to the other side I loose my connection.
Any ideas?
Do I need to assign an anchor?
Do I have to create an identical WLAN on both WLC?
