Mobility Service Engine MSE Self-signed generation
aakash-agarwal
Frequent Visitor
Frequent Visitor
I have MSE and its self signed certificate is expiring, I would like to know how to regenerate the license i dont find much of the option:
i can find the script but i don't find option to generate the self-signed certificate
/opt/mse/framework/bin/
CertMgmt.sh
Rasika Nayanajith
Hi Aakash,
Pls refer this document for certificate management in MSE 8.0.x
https://www.cisco.com/c/en/us/td/docs/wireless/mse/8-0/MSE_CMX/8_0_MSE_CAS/8_0_MSE_CAS_chapter_010001.html
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Hi Aakash,
Rasika
aakash-agarwal
Frequent Visitor
Frequent Visitor
Response from TAC: (make sure you HA if HA needs extra steps i will document in my blog)
Step 1:
MSE#./CertMgmt.sh
Step 2:
Use Option 9 (This will show you your current cert) Take the session output.
Step 3:
Then clear out the cert using Option 8
Step 4:
MSE will reboot, when it comes back up, log back into the MSE CLI
Step 5:
Go to cd /opt/mse/framework/bin/
Execute this command  installNewCertificate.sh
You can then run CertMgmt.sh to verify the cert is there.
This will give you another 3 year cert.
Thank you for providing steps to do it Akash
Rasika
