mobilty
bluesea2010
Level 7
Level 7
I have the below setup, there are two wlc's  one is  cisco the other one is  non-cisco,
(core1 is in site A and core 2 is in site B)
is it possible a  seamless roaming experience?
what are the drawbacks of the below setup ?
What is the best solution?
9 Replies 9
Arshad Safrulla
Seamless roaming is not possible with non-cisco wlc's.
Leo Laohoo
Let's not get ahead of ourselves here.  Look at the basics first:  Site A and Site B.  What is the distance between the two Sites?
The distance between Site A site B is only  550 meter .
it is connected with a fiber cable.  we can say site B is an extension of site A .but it is managed by differnt  group of people .
Regarding the open space between Site A and Site B, is there WiFi coverage?
@Leo Laohoo
yes
@bluesea2010 wrote:
yes
So this answers the question of "seamless roaming".  Since there is a coverage gap between Site A and Site B, how is a wireless client expected to retain wireless connectivity when there is no wireless coverage?
Therefore, the answer to the question is a "no".
Hi @Leo Laohoo
Regarding the open space between Site A and Site B, is there WiFi coverage? , Yes
What I mean is there is no coverage gap  between site A site B
from site
Ok, thanks for the clarification.
Then dang.  That is an inter-controller roaming.
Mark Elsen
 - Check these compatibility notes too for seamless roaming experience :
             https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ircm_aireos_rls
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
