Model number of the power adapter for Cisco access point CAP3502I-A-K9 ,
Ibrahim Jamil
Level 6
Level 6
Hello International friends
what is the model number of the power adapter for Cisco access point CAP3502I-A-K9 ,
I m surprised that power adapter of Cisco ip phone ( CP-PWR-CUBE-3)  able to power this Access point
your input is very much appreciated
thanks a lot
Ibrahim jamil
2 Accepted Solutions
CP-PWR-CUBE-3= power supply for Cisco IP phones.
- Input voltage: 100V - 240V AC
- Max. input power: 5A
Input Power Requirements for 3502 AP:
• AP3500: 44 to 57 VDC
• Power Supply and Power Injector: 100 to 240 VAC; 50 to 60 Hz
as you can see in above power requirement ...whcih supports both thats the reason it working with AP as well.
It will work for 3502 AP but if cisco dont recommand it then dont use it.
Dont forget to rate helpful posts
yes i can see it.
Again it will work for 3502 but no one give you a 100% surety.
Best is to have the real power supply for 3502 AP as per cisco recommandation in data sheet.
8 Replies 8
Sandeep Choudhary
As per datasheet: https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1250-series/data_sheet_c78-594630.html
Local power supply is:
Cisco AP3500 Local Power Supply (AIR-PWR-B=)
Dont forget to arte helpful posts
This is the Cisco AIR-PWRINJ5. As long as a power adapter fill the requirements it will work.
https://www.cisco.com/c/en/us/td/docs/wireless/power/quick/guide/pwrinj5.html
-If I helped you somehow, please, rate it as useful.-
Hello flavio
this link y provide  is a power injector for non-PoE switch
thanks
guys
why and how the power adapter of cisco IP Phone power this AP 3500??
THANKS
Hello sandeep
pls find attached power adapter specs
thanks
yes i can see it.
thanks for u time guys to clarify my concern by responding quickly to this thread
