Model of Cisco Router
narendar.a
Is it possible to find the device model by serial number, if so can someone tell me how to find the Model of Cisco Router with a serial number.
Narendar
Yes sure...
copy ( https://cway.cisco.com/mydevices ) and paste it on your internet browser address bar.
enter your credentials ( your cisco ID ). choose ADD Devices. and follow the instructions.
chick the 2 attachments iv uploaded also
Hope that could help.
5 Replies 5
saif musa
Level 4
Level 4
Chick below, it will help
https://supportforums.cisco.com/discussion/12564901/serial-number-lookup-tool
Thank you Saif.
Can you please direct me where to start looking. i'm completely new to this stuff.
Yes sure...
Thanks for the details.
Never mind, if you now found a solution for your enquiry then please choose "correct answer" to close this discussion.
