Monitor and Enhance local modes - wIPS
ahmedfouad
Hello ,
can i mix between a Monitor mode APs and Enhanced local mode ones to be both served by MSE for wIPS services ???
or the AP mode must be unified ?
thanks
Rasika Nayanajith
That should be fine.
Rasika
**** Pls rate all useful responses ****
gohussai
Level 4
Level 4
Ahmed you can use.
check the link for ref: - http://www.cisco.com/c/en/us/td/docs/wireless/technology/wips/deployment/guide/WiPS_deployment_guide.html
Abhishek Abhishek
ELM vs Dedicated MM
Figure 4 provides a general contrast between the standard deployments of wIPS MM APs and ELM. In review, the typical coverage range for both modes suggests:
  • Dedicated wIPS MM AP typically covers 15,000-35,000 square feet
  • Client-serving AP will typically cover from 3,000-5,000 square feet
Figure 4 - Overlay of MM vs All ELM APs
In the traditional Adaptive wIPS deployment, Cisco recommends a ratio of 1 MM AP to every 5 local mode APs, which may also vary based on network design and expert guidance for best coverage. By considering ELM, the administrator simply enables the ELM software feature for all of the existing APs, effectively adding MM wIPS operations to local data-serving mode AP while maintaining performance.
On-Channel and Off-Channel Performance
A MM AP utilizes 100% of the radio’s time for scanning all channels, as it does not serve any WLAN clients. The primary feature for ELM operates effectively for on-channel attacks, without any compromise to the performance on data, voice and video clients and services. The primary difference is in the local mode varying off-channel scanning; depending on the activity, off-channel scanning provides minimal dwell time to gather enough information available to classify and determine attack. An example may be with voice clients that are associated and where AP’s RRM scanning is deferred until the voice client is dis-associated to make sure service is not affected. For this consideration, ELM detection during off-channel is considered best effort. Neighboring ELM APs operating on all, country or DCA channels increases effectiveness, hence the recommendation for enabling ELM on every local mode AP for maximum protection coverage. If the requirement is for dedicated scanning on all channels full-time, the recommendation will be to deploy MM APs.
These points review differences of local mode and MM APs:
  • Local Mode AP - Serves WLAN clients with time slicing off-channel scanning, listens for 50ms on each channel, and features configurable scanning for all/country/DCA channels.
  • Monitor Mode AP - Does not serve WLAN clients, dedicated to scanning only, listens for 1.2s on each channel, and scans all channels.
