more than one VCI string for DHCP option 43
mchockalingam
Hi All,
I have a mixed environment where some APs are 1142s and some APs are the older 1131AG. These 2 APs have different VCI strings. Is it possible to add more than one option 60 so that option 43 would return WLC's addresses?
Meena
mchockalingam
I found a way to add multiple VCI strings for option 60 on the DHCP server.
George Stefanick
Seems like you go it... If you need help in the furture I created a video at http://www.my80211.com/cisco-wlc-labs/2009/7/4/cisco-dhcp-option-43-configuration-nugget.html that walks through the DHCP option 43 process.
I was able to make it work with one VCI string (1140 AP) but I had trouble adding two VCI strings (1130 and 1140APs). It was a syntax issue and I was able to fix it.
Meena
