Most stable OS for 4402 WLAN controller
ccolom
What is the most stable OS for the cisco 4402 WLAN controller?
5 Replies 5
rnigam
4.2.130.0 for 1240, 1500, 1130, and 1500 series. If you use the 1252 in .n mode you need 4.2.130.6 which is only available from TAC and is not published.
Thanks for your recomendation, but why not use 4.2.176?
Thanks.
You can if you have the 1252's.... this does replace the 4.2.130.6. But if you don't have 1252's, then stick with the 4.2.130 code.
-Scott
rnigam
Also you asked for the most stable so I gave you the most stable. If your question would have been 'which are the stable version' probably my answer would have involved that image too.
