MR Interface
JFer
Community Member
The data rate between AP and SW / 1 is capped at 100 Mbps and operating at half duplex
The switch port is configured in auto mode. I have set it to 100 full duplex and 1000 full duplex, but the message still appears. I’m not sure if the LAN port of the AP needs to be configured
ww^
Meraki Community All-Star
Put both on auto.
Make sure the cable is good and fully plugged in on both sides
Try another switch port
Vivek5
Level 3
Level 3
What is switch and Ap model ?
Did you check the cable ? Is it ok ?
Yes,you need to check the port settings on AP local status page too.
mloraditch
As others have said checking the cabling as that's the likely culprit usually, if you have Meraki switches you can use this tool: https://documentation.meraki.com/MS/Monitoring_and_Reporting/Using_the_Cable_Test_Live_tool
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
KunalKonduru
Hi @JFer
I would recommend you to put both ends on auto. Secondly, make sure the cable is good (Bypass the patch panel if any and directly have the AP connected to the switchport). Lastly, try another switch port. Alternatively, can also try to connect another test device using same cabling to same switchport to verify if the issue subsides.
If the problem continues, contact our support hotline/open a case for further troubleshooting.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
