Mr.
Ameh
Community Member
Good day every one,
My CCNA-RS will expire soon, and I will like develop my carrier on wireless, what should be the next exams appropriate to write?
omz
There is no technology-specific CCNA anymore. You can do a new CCNA that gives an associate-level overview of the new tech. Next Wireless specific cert is CCIE Wireless.
https://www.cisco.com/c/en/us/training-events/training-certifications/certifications.html?carousel=3#~certifications
As already mentioned, there is no CCNA Wireless anymore. But the next step is not CCIE Wireless. On the Cisco curriculum, the Specialisations for Wireless Implementation and Design are the next steps. There is a Wireless foundation course that teaches the basics that everyone should know before going further with the specializations.
For a vendor-neutral education take a look into the CWNA from cwnp.com.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
on a certification path .. the only wireless specific cert is CCIE
does specialisation exam give a cert?
Yes, they give you a "Specialist Certification":
  • 300-430 ENWLSI: Cisco Certified Specialist - Enterprise Wireless Implementation
  • 300-425 ENWLSD: Cisco Certified Specialist - Enterprise Wireless Design
