MR36 connection issue
rzabayli
Community Member
Hi, dear community users!
We have faced an issue with brand new MR36 access points.
Years before for our company we purchased MR33 access points and they are working properly all the time, still using them in our branches.
Month ago we have purchased several MR36 ACs and configured them as previous models.
But sometimes wireless network disappears for a few seconds. It is a repeating process, like every 2-3 minutes.
ACs are connected to also new Cisco switches (C100FE-48P-4G-L). ACs are using PoE, not a Power Adapter.
This problem is actual right now in 3 branches. Same switch, same MR36 AC.
We can see nothing strange from monitoring in Meraki dashboard.
Maybe there is someone who faced the same problem? Or could it be caused by not proper PoE?
Thank You in advance.
12 Replies 12
rzabayli
Community Member
rzabayli
Community Member
At first we thought this was caused by our DHCP, but MR36 looks more like rebooting intervally.
ppurroy
I would suggest you open a Meraki support case to see why the devices are booting. This should not be happening?
ppurroy
Also, please make sure you are running a Stable or Release Candidate image:
Stable right now: Version 30.6
rzabayli
Community Member
I will check it, thanks!
CMR
Meraki Community All-Star
Does it give a boot reason in the event log?
If my answer solves your problem please click Accept as Solution so others can benefit from it.
rzabayli
Community Member
Last week we have upgraded one MR36 access point to 30.6 firmware and the issue has been resolved.
However, today we asked Meraki Support to update 2 APs (also MR36 model) more, and this time it doesn't help.
We tried to test one MR36 in Head Office (all problematic APs are connected in our branches) and it works properly, without reboot and etc. Is there any requirements for switch's port, where we are connecting AP? Maybe MTU size or something else? As I mentioned, MR33 APs are working without an issue.
ppurroy
Check with support to make sure that the MR36s all have downloaded correctly the MR30.6 version, sometimes this does not happen correctly.
Also, why don´t you upgrade the whole network, not just certain devices to MR30.6. MR30.6 is the current stable image and it works great with MR33s and MR36s, you should strive to have your network in the latest stable image or close to it. Upgrading only certain units in a network is allowed for troubleshooting purposes but this is not intended or recommended to be done for normal operation.
rzabayli
Community Member
@ppurroy we wanted to see if our issue will be resolved via firmware, that's why we asked for "per device" update.
rzabayli
Community Member
rzabayli
Community Member
That is what shows in Event log.
I did a research and everyone keep saying that is a physical issue.
But we have tried several Ethernet cables and tried to change Switch's port.
ppurroy
Sure, that is exactly why this is done by support. As you mentioned this had good results on your first AP, I suspect the APs that were added to this version later on have not yet downloaded the correct image. Support can confirm this.
Like you said if this is fixed in the firmware upgrade then you should move the whole network to the MR30.6 or current stable version at the time.
