MR36 current client connection widget
B_97
Community Member
I have a question about the current client connection widget.
I have a Meraki Network made by ten MR36 APs. All APs are connected via Ethernet ports to switches in the infrastructure (not Meraki switches). So, I have no meshed APs.
Documentation (Client Details Page Overview - Cisco Meraki Documentation ) reports that the client connection widget shows the path a client made to access the internet.
In my Meraki Network, when I open a client detail page, the client connection widget looks like this:
What does it means?
I expected the client connection widget to show only one AP, not three.
Thanks for your help!
aleabrahao
Meraki Community All-Star
So this is probably a bug, I would open a support case for them to investigate.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
Are you sure you don't even have any AP in mesh mode?
B_97
Community Member
Yes, I'm sure because I see APs on the switches they are connected to.
Also, from dashboard I see all APs as gateway, no one as repeater...
aleabrahao
B_97
Community Member
Thanks for your help! I'll follow your suggestion
