MR57
ahmed01baryoul
Community Member
hello community
i'm facing a problem through the configuration of SSID of the MR 57
i create an account meraki then i create a network and attach the device to it
mooving on , i configure an SSID for the MR57 but the ssid does not appear in the wifi list but an SSID named "Meraki setup" appears
what is the problem ?
5 Replies 5
If you see this SSID, likely, the AP could not register with the cloud.
I would first reset the AP if it was used before somewhere else and make sure that it is connected to a port where a valid IP config is provided by DHCP.
Then make sure the AP comes online in the dashboard. After that you should see your configured SSID.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
thanks
should i delete it from the Meraki dashboard ?
then after reset it i add it ?
You can leave it ion the dashboard network for the reset. It should come online shortly after.
aleabrahao
Meraki Community All-Star
A very relevant question here is, does the ap appear as online on the dashboard?
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
thanks
the problem is resolved
