MR78
ezaiello
Hello Team, I hope all is well.
I need to add the MR78 to my Network. I cannot do it on the dashboard: https://n508.meraki.com/ezaiello_wireles/n/5J2Clcewb/manage/usage/list and on my list of devices, I have MX68 & MR44 https://devices.cisco.com/setup/network/wifi-config
I must set up the MR78 and leave it downstairs as the signal is too weak.
I appreciate your help,
Thank you
Ezequiel
6 Replies 6
ww^
Meraki Community All-Star
ezaiello
I am not able to add it. What are the steps I should follow to add it?
ww^
You should go the the inventory, claim the order /serial.
Then the device should be seen in the inventory, then you can add that device to the network
ezaiello
Again, I do not see the inventory. I opened a case at Cisco and they told me to reach out to you. Any chance we can do a WebEx to check this?
aleabrahao
@ezaiello the @jdb1 and I are not Meraki employee. You can read the documentation and follow the steps.
https://documentation.meraki.com/General_Administration/Inventory_and_Devices/Using_the_Organization_Inventory
If you are not able to se the inventory, probably you are not organization admin.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
I believe you've been directed to the wrong place for assistance. You do not have appropriate admin rights. I will DM you
