but I'm not sure about the compatibility between the MSE and the WLC.
Here is the compatibility information.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148604
My WLC is in 7.6.100 version
You should consider upgrade this to min 7.6.130.0 as that is the stable code of 7.6.x software train.
MSE is 3310 model. Reviewing documentation, the MSE can only update until 7.3 version. Somebody knows if the version between wlc and mse must match, or which are the restrictions.
It does not need to be exact match between WLC & MSE versions. Refer release notes of each product & version, it will listed the new features added in each releases. Since MSE 3310 not supporting 7.3.x onward, I would plan for MSE migration anyway. You can go with VM in later versions of MSE & no need to buy hardware for that.
Additionally, i can use Prime I or WSC, we have both systems
Go with Prime as WCS is not supported any longer. What's the reason still keeping the WCS ?
Rasika
**** Pls rate all useful responses ****
