MSE - HA issue
Scott O'Brien
Level 2
Level 2
Hi Guys,
I have an issue with my MSE's were I failed over from the Primary MSE to the Secondary MSE and now it will not fail back, if I shutdown the secondary MSE the Primary takes over ( status in cisco prime says it has lost connection to secondary as the secondary is shutdown)
once I boot up the Secondary in instantly takes over, and if I click failback in prime it refuses too. Also when I shutdown the Primary MSE 37.151 the VIP IP can not be pinged.
I have started and stopped the MSE service on both machines, I have rebooted and also re-run the startup script.
Scott
0 Replies 0
